mansus
Aug 30, 2016Aspirant
R7800 wireless clients cannot connect to lan clients
Hello, I have the latest firmware 1.0.2.04 on R7800 and have an issue where my wifi client cannot access servers on lan on the same router. I found suggestions about firmware resets and turning o...
- Nov 22, 2016
evel I'm using Kong Mod from myopenrouter.com. It's a straightforward process on how to replace the firmware (just look at the latest article). For VLAN tagging, you'll need to create a VLAN on eth0 (default WAN) interface (Setup->Networking) and assign a newly created port as WAN port on the same page. Once you're online - you can easily do the rest (wifi, services, etc). WIFI->LAN works right away.
Thx, Mansus.
Dec 21, 2016Guru - Experienced User
Im sure users can go directly to DD-wrt or OpenWRT sites to find out if they support this model officially.
streilu
Dec 22, 2016Guide
DD-Wrt is working on our R7800, but I didn't get VLAN on the WAN-Interface to work.
- hamditDec 22, 2016Aspirant
i think also 5Ghz Wifi isn't working on DD-WRT as i remember
- Mietek154Dec 22, 2016Guide
How it is going with support? Any news?
A lot of people waiting for any feedback. If problem was reported almost 3 months ago and suport still cannot fix it, Netgear should propose device replacement to new (without this problem, model same or better) or money return.
Can you please let us know what is the current status and official Netgear statement about this issue.
