mansus
Aug 30, 2016Aspirant
R7800 wireless clients cannot connect to lan clients
Hello, I have the latest firmware 1.0.2.04 on R7800 and have an issue where my wifi client cannot access servers on lan on the same router. I found suggestions about firmware resets and turning o...
- Nov 22, 2016
evel I'm using Kong Mod from myopenrouter.com. It's a straightforward process on how to replace the firmware (just look at the latest article). For VLAN tagging, you'll need to create a VLAN on eth0 (default WAN) interface (Setup->Networking) and assign a newly created port as WAN port on the same page. Once you're online - you can easily do the rest (wifi, services, etc). WIFI->LAN works right away.
Thx, Mansus.
streilu
Dec 23, 2016Guide
Good morning people,
so I asked if there is any progress and mentioned the two threads here in the board.
Immediately got an answer if I can provide my configuration.
They will forward the configuration to the engineering department, so I hope they can figure out what's causing this issues.
Mietek154
Dec 27, 2016Guide
Any news?
