mansus
Aug 30, 2016Aspirant
R7800 wireless clients cannot connect to lan clients
Hello, I have the latest firmware 1.0.2.04 on R7800 and have an issue where my wifi client cannot access servers on lan on the same router. I found suggestions about firmware resets and turning o...
- Nov 22, 2016
evel I'm using Kong Mod from myopenrouter.com. It's a straightforward process on how to replace the firmware (just look at the latest article). For VLAN tagging, you'll need to create a VLAN on eth0 (default WAN) interface (Setup->Networking) and assign a newly created port as WAN port on the same page. Once you're online - you can easily do the rest (wifi, services, etc). WIFI->LAN works right away.
Thx, Mansus.
streilu
Jan 03, 2017Guide
Seems that there is some progress going on.
I did also provide config, debug logs and so on.
Also mentioned the two threads here.
Responds got quicker these days.
- Mietek154Jan 21, 2017Guide
Responds got quicker these days.How it is going ? Any news?
- evelJan 27, 2017Aspirant
I just updated to the new firmware. Everything worked fine for about 5 minutes. I could access my wired NAS from my wireless laptop. I played a music file off of it. Went about doing something else, came back, not working again. Tried multiple resets, still not working.
Not cool.
- streiluJan 30, 2017Guide
No news until now, just asked for some status update from netgear.
- streiluFeb 01, 2017Guide
Short update:
Netgear Engineers will connect to my place on friday or monday and check the problem.
Don't know what exactly they will do, but let's see.
- Mietek154Feb 07, 2017Guide
streilu wrote:Short update:
And how was it? Did they connect to your home router and check the issue?
I spoke today with my local customer support and there is still no update after a month since i created the case. I asked anylyst how to get my money back.
They waste our time... prentending that they're working on this issue.
