mansus
Aug 30, 2016Aspirant
R7800 wireless clients cannot connect to lan clients
Hello, I have the latest firmware 1.0.2.04 on R7800 and have an issue where my wifi client cannot access servers on lan on the same router. I found suggestions about firmware resets and turning o...
- Nov 22, 2016
evel I'm using Kong Mod from myopenrouter.com. It's a straightforward process on how to replace the firmware (just look at the latest article). For VLAN tagging, you'll need to create a VLAN on eth0 (default WAN) interface (Setup->Networking) and assign a newly created port as WAN port on the same page. Once you're online - you can easily do the rest (wifi, services, etc). WIFI->LAN works right away.
Thx, Mansus.
Mietek154
Jan 21, 2017Guide
streilu wrote:
Seems that there is some progress going on.
I did also provide config, debug logs and so on.
Also mentioned the two threads here.
Responds got quicker these days.
How it is going ? Any news?
evel
Jan 27, 2017Aspirant
I just updated to the new firmware. Everything worked fine for about 5 minutes. I could access my wired NAS from my wireless laptop. I played a music file off of it. Went about doing something else, came back, not working again. Tried multiple resets, still not working.
Not cool.
