mansus
Aug 30, 2016Aspirant
R7800 wireless clients cannot connect to lan clients
Hello, I have the latest firmware 1.0.2.04 on R7800 and have an issue where my wifi client cannot access servers on lan on the same router. I found suggestions about firmware resets and turning o...
- Nov 22, 2016
evel I'm using Kong Mod from myopenrouter.com. It's a straightforward process on how to replace the firmware (just look at the latest article). For VLAN tagging, you'll need to create a VLAN on eth0 (default WAN) interface (Setup->Networking) and assign a newly created port as WAN port on the same page. Once you're online - you can easily do the rest (wifi, services, etc). WIFI->LAN works right away.
Thx, Mansus.
streilu
Feb 25, 2017Guide
Update:
Yesterday I went back from DD WRT to stock and the engineers connected again.
Now I had the chance to show them the things not working.
After that they gathered many debug logs and also changed the debug script on my R7800 to get even more logs.
Let's see when I will get feedback if they found the cause of this strange behaviour.
I will report back here!
