jim_0
Jun 06, 2022Aspirant
R7800 with vulnerable Netatalk detected by nessus scanner
did a nessus scan on my internal network and the only critical vulnerability is on my router netatalk version, how do i remedy this? CRITICAL Netatalk OpenSession Remote Code Execution Descrip...
Jun 07, 2022Guru - Experienced User
microchip8
Jun 07, 2022Master
You can try installing Voxel's firmware. It's stock with optimizations and bug fixes. I don't think it suffers from the Netatalk issue
