Jumper20
Mar 12, 2019Aspirant
R7800 X4S, how to correctly set up QoS?
Hello, I'am having trouble setting up QoS as ping spikes are still an occurance on my main computer. As for my connection background it is wisp -> poe injector -> R7800. Smart TV and my personal co...
- Mar 12, 2019
.62 firmware still has issues for some. You may need to downgrade to .52 and wait until NETGEAR fully fixes it
shadowsports
Mar 12, 2019Hero
Greetings,
What FW version are you using? Some of the recent FW versions for the R7800 had issues with ping spikes.
Second. If you want to game and stream TV, subscribe to higher bandwidth and forego QoS all together. Its nothing but trouble.
- Jumper20Mar 12, 2019AspirantFirmware 1.0.2.62
If bigger speeds would be an option, we would choose that. In our current location only wisp's can supply the connection with the maximum plan being down 25 mb/s but the price is not worth it. The quality of provided service for reference lets say ping to google.com is 11ms and games to closest server have 5-10ms ping. The problem is ping spikes- microchip8Mar 12, 2019Master
- Jumper20Mar 12, 2019AspirantI really hope so
