geno1329
Dec 22, 2020Guide
R7800
Hi Since updating my firmware to V1.0.2.78 for my Nighthawk(R) X4S R7800 My internet connection have slowed down , stop working and on and off Called spectrum internet , hard reset both modem and...
- Dec 22, 2020
Most stable R7800 is the .68 firmware. Get it from here https://www.netgear.com/support/product/R7800.aspx (click on the + sign lower left)
michaelkenward
Dec 23, 2020Guru - Experienced User
geno1329 wrote:
Factory reset the router again , got spectrum to replace my modem with a new one and still the problem there.
What is that modem?
V1.0.2.78 has been fine here.
After they replaced the modem, did you go through the recommended reboot process?
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
- geno1329Dec 23, 2020Guide
The modem is Hitron E31N2V1
and yes i did all that . i even went to the spectrum website to resend the signal and reset the modem
- michaelkenwardDec 23, 2020Guru - Experienced User
OK. Straightforward modem with nothing routery to complicate matters. Unless the ISP has specified a particular customised version.
im gonna update this after the tech guy from spectrum. For now im using version firmware 68 as above person suggested.
