Dljj's avatar
Dljj
Follower
Dec 24, 2020
R7800
What wireless access points would be best for my WiFi router
X4s AC2600
  • Are you looking for access points or extenders?
    I know they're different but just seeking a little clarity.
    Reason why is an access point hardwires into your router. You'd just choose an access point that had the specs you wanted and hardwire it in.
    If you're looking for a wireless extender, then I'd recommend one of the line of triband extenders.
1 Reply
  • plemans's avatar
