Mirko76
Jan 01, 2022Aspirant
R7800
SALVE. Risocontro problemi con i ddns. Versione firmware del router V1.0.2.86 Ho notato che se inserisco i ddns del server no ip(che da anni che uso e confermo tutti i mesi) se spengo il rout...
Mirko76
HELLO.
I have problems with the ddns.
Firmware version of the router
V1.0.2.86
I noticed that if I enter the server's ddns no ip (which I use for years and confirm every month)
if I turn off the router manually, it no longer automatically updates ip dns.
In the show status section I get this message.
No update action. IP address not present on the Internet port.
apparently everything worked before.
practically it doesn't update me any more ip ipv4 of the server (noip) which changes on the server, but the netgear does not automatically update its change of address.
i tried to do a downgrade to previous version too, but nothing to do same problem.
since the router is cascaded i tried to do a magic.
ddns loaded on the main modem
and it all works by magic.
working cameras.
but I can't use the negear ftp (internet) server because I can't use the ddns section of the negear because it doesn't update the server's ipv4.
this problem I detect it only on dns free of no ip.
if I put the paid ones everything works, try already done.
then I wonder and say dear netgear and no ip.
since you are affiliated.
We sort it out or I have to pay this $ 30.
I hope it is a momentary problem and that it will be resolved as soon as possible, perhaps with a firmware update.
I am attaching the sample images to understand the problem
2 host names to make you understand
astalavista updated by the modem.
heets1976 did not update after restarting the router
I created two hosts for you to understand, I only use one to make everything work
V1.0.2.86
working cameras.
