CazHux
Jan 18, 2022Follower
R7800
Hi I used this a few years ago in italy and now want to set it up in the uk. I’ve tried with the nighthawk app and I’m obviously doing something wrong. I get the message can’t connect to the network a...
Kitsap
Jan 18, 2022Master
Recommend you steer far away from the "app". It is the source of many problems.
After you have done the firmware default reset, connect direct to the R7800 with an ethernet cable and a computer. Use a web browser to connect to the Graphical User Interface (GUI) and complete your setup.
Note there firmware updates for the R7800 over the past couple of years.
