stepdrill
Dec 11, 2022Aspirant
R7800
Just wondered what everyone is upgrading to from the R7800? Mine has held up pretty good but seems like I'm starting to get a delay. Just curious.
Dec 11, 2022Guru - Experienced User
The R7800 is a pretty rock solid router. I'd rate it one of the best AC routers there is.
So I'd be curious what speeds you pay for and what delay you're seeing?
Maybe you don't need an upgrade, maybe just some settings changes or a just a factory reset and reinstall.
Sometimes that can help out a bit.
Or even a modem/gateway change if thats the issue.
- stepdrillDec 11, 2022Aspirant
I have 1gig download 50 upload from Point broadband. It doesn't seem as snappy as in the beginning. I do have 2 PS5 and one Xbox always going...lol. Maybe I'll just do a reset, I haven't done that since I bought it 3 years ago. Thanks
- michaelkenwardDec 11, 2022Guru - Experienced User
Any device designed to work at up to gigabit is hitting a celing when you throw it at Gb Internet.
But "doesn't seem as snappy" is a bit subjective.
Do you have any measurements that can add some numbers to your gut feelings?
