Elmer157
Nov 27, 2023Tutor
R7800
Have a Motorola 8600 modem and shows working fine. Moved my system to a different part of the house. Issues began. Modem indicates internet but R7800 indicates offline w error message 401 Unauthor...
Nov 28, 2023Guru - Experienced User
Does it work fine if you move it back to the old location?
Elmer157
Nov 29, 2023Tutor
Still the same 401 code. I did not place the modem and router back to original location. Location is different part of the house. I know the modem is working,as all the lights are up and running. The R7800 are flashing white as in the past. 2.4 and 5 g both flashing.
