ajaychoudhary9
Sep 07, 2021Aspirant
R7850 - Power adapter
Could I get some help in finding the right power adapter for my nighthawk AC3000 -R7850. Tried searching on few sites but I am not able to find the netgear original charger.
Sep 08, 2021Guru - Experienced User
netgear doesn't sell replacment power supplies.
But luckily you can buy third party power supplies. Just make sure it has the exact same output voltage and polarity. It can have a higher amperage but not lower or you'll have stability issues.
michaelkenward
... and if you are lucky you will find a replacement that lists itself as being compatible with your Netgear router.
They are pretty standard. Something that works with one router should work with others. But check the specs.
