TLFerg53
Aug 07, 2021Tutor
R7850 Internet Speed Slower Than ISP
I have a Night Hawk R7850 which gives good service throughout the house, but the Interent speeds top our at around 125Mpbs on 5G and only 75Mpbs on 2.4. Yet, when I connect a laptop directly to the ...
Aug 07, 2021Guru - Experienced User
What speed to you get hardwired into the R7850?
What firmware is on the router?
What modem is it from spectrum?
Are you using access controls, qos, traffic monitoring, or parental controls? Try disabling them and rebooting if so.
- TLFerg53Aug 07, 2021Tutor
Get around 115Mpbs when hardwired.
Firmware is V1.0.5.74.
Spectrum Modem is E31N2V1, Hitron Technologies, Inc.
Parental Controls are Off.
Traffic Meter is Off.
Turned QOS off and speeds:
Hardwared: Jumped to around 230 from around 150.
Wireless: Jumpers to around 215 from around 135.
- plemansAug 07, 2021Guru - Experienced User
Try a factory reset and reinstall.
During the install, leave access controls, qos, traffic monitoring, and parental controls all off.
Then try the wired/wireless testing and report back.
- TLFerg53Aug 08, 2021TutorThat seems to have helped! I can get over 400 now occasionally, but it averages in the mid-200’s, much better than before. I did change the SSID’s back to what I had them from the default NETGEAR50, so I wouldn’t have to go around and update the various devices like thermostats, Alexia, etc., but that shouldn’t matter, should it?
Thank you!
