dprostko
Dec 30, 2021Follower
R7850 needs rebooted often. Just stops sending signal to all devices. Modem signal remains strong.
Seems like there is a hiccup in the modem signal and the router stops communicating with devices. Router needs rebooted to resume operation. Is there a setting I can adjust to make it restart automa...
Dec 30, 2021Guru - Experienced User
No.
but you can work on figuring out why your modem is having "hiccups" and causing it to loose connection.
