w1
Dec 02, 2020Initiate
R7850 Nighthawk AC3000 Router Firmware
I have an R7850 Nighthawk AC3000 Router that randomly drops internet from some of my devices. After reading several other threads regarding this problem, I want to re-install the firmware on it. It i...
- Dec 03, 2020
w1 wrote:
So then the R7850 Nighthawk AC3000 Router is the same as the R7850 Nighthawk AC3200 Router?
That's one of the hazards of using those "AC" labels.
AC3000 and AC3200 are not reliable guides to model numbers. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
So stick with the R7850 as the model number and you'll be fine.
Glad it worked out.
Dec 03, 2020Guru - Experienced User
You can find the firmware here:
https://www.netgear.com/support/product/r7850.aspx#download
you're not actually on the most recent. I'd recommend manually instalilng the most recent, factory resetting, and doing a clean install (not from backup)
michaelkenward
In addition to the sound advice from plemans read this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- w1Dec 03, 2020Initiate
First of all, thanks for responding. So then the R7850 Nighthawk AC3000 Router is the same as the R7850 Nighthawk AC3200 Router? I downloaded the 1.0.5.64 firmware and installed it. Then I did a factory reset and a fresh install of my router. Everything is up and running. Time will tell if this makes any difference. Thanks again for your advice.
- michaelkenwardDec 03, 2020Guru - Experienced User
Glad it worked out.
