WLMBRM
Feb 28, 2021Initiate
R7900 internal speedtest showing WAY slower speed than external speed tests
First post, I searched but couldn't find the exact problem I'm having. I have Spectrum 1GB/40MB service. When I run speedtests (Spectrum speedtest, Speakeasy speedtest, Ookla, etc) all show my D...
- Feb 28, 2021
Are you using the nighthawk app?
Reason why is the nighthawk app hosts the test of the router and then rarely chooses the proper server.
If you're getting full speed off a pc/laptop hardwired into the router, then its getting full speed and working properly.
I usually don't recommend using the built in app speedtesting if you have >500mbps.
Feb 28, 2021Guru - Experienced User
- WLMBRMFeb 28, 2021Initiate
Makes sense. No, not using the Nighthawk app, this was through the router login. I was just taking a look around and after running the speedtest several times, became curious as to why. I realized I was getting full speeds elsewhere so I didn't think anything was setup wrong but was curious as to why the huge delta in speeds. Didn't think about it pinging a different server....my bad! Thanks for the quick reply!
