WLMBRM's avatar
WLMBRM
Initiate
Feb 28, 2021
R7900 internal speedtest showing WAY slower speed than external speed tests
First post, I searched but couldn't find the exact problem I'm having.   I have Spectrum 1GB/40MB service.  When I run speedtests (Spectrum speedtest, Speakeasy speedtest, Ookla, etc) all show my D...
  • plemans's avatar
    Feb 28, 2021
    Are you using the nighthawk app?
    Reason why is the nighthawk app hosts the test of the router and then rarely chooses the proper server.
    If you're getting full speed off a pc/laptop hardwired into the router, then its getting full speed and working properly.
    I usually don't recommend using the built in app speedtesting if you have >500mbps.
