rogueeva27
Jan 13, 2022Aspirant
R7900 Is there a limit to the number of connected devices on 2.4 Ghz band?
I have the R7900 and have recently started adding a smart light switches, I have reached the point where when trying to add any device onto the 2.4 Ghz band and I am unable to. I've looked through...
rogueeva27
Jan 21, 2022Aspirant
Thank you, Plemans.
- Dual-band WiFi 5 routers: At least 50 client devices
- Single-band WiFi 5 routers: At least 32 client devices
Interestingly enough my router is a Tri-Band WiFi 5. So maybe less per band. Regardless I think your options are a possibility.
Do you have any experience with Smart Connect—Same WiFi network name on 2.4 & 5GHz for automatic band selection?
I'm wondering if doing this would fix my issue. Let the router handle what band works best for each device. I'm thinking of using smart connect first to see what happens and then using an extender.
Thank you again.
microchip8
Jan 21, 2022Master
Smart Connect is horribly broken on NETGEAR routers. I wouldn't recommend it.
- plemansJan 22, 2022Guru - Experienced User
I initially started out hating smart connect. As time has went on, I've learned to appreciate it. But I have my higher bandwidth devices (4k tv's, gaming pc) all hardwired in. Its easier for the family/friends as they don't have to worry about which band to connect to.
