clattin
Dec 12, 2021Follower
R7900 stops broadcasting internet over wifi almost daily
Almost everyday now for the last couple of months, the internet via wireless connections gets lost somehow. Wired connections continue to work and wifi access to other resources on the network are functioning properly. It requires me to reboot the router everytime. I have made no configuration changes in over a year and the firmware is up to date (V1.0.4.46_10.0.53).
Any help is greatly appreciated!
Thank you,
Chris
1 Reply
What modem/gateway are you connected to?
It only started a couple months ago? there was a new firmware pushed out in september.
Sometimes a factory reset after an update can help. did you try a factory reset and reinstall? (don't install from a backup)
