eggt4rt
Aug 31, 2026Aspirant
R7900P - Unable to access admin page after firmware update
Hi all! Happened a while ago. Last I recall, I updated to the latest firmware and can no longer access the admin page via the app or routerlogin.net. I get a connection timeout from the webpage ...
eggt4rt
Thanks for the reply!
Since I am no longer able to verify, I assume it is the latest available one: 1.4.4.94
I have tried different browsers on multiple devices and in incognito mode trying both routerlogin and 192.168.1.1
From my understanding, resetting the router does not make any changes to the firmware. I don't know if I want to take the chance to reset it and not be able to access the admin page to set everything back up since it is currently working.
Aug 31, 2026Guru - Experienced User
Can try inputting a password 3 times then you should get a recovery PW screen using a browser.
If this fails, you'll need to factory reset the router and setup from scratch.
