eggt4rt
Aug 31, 2026Aspirant
R7900P - Unable to access admin page after firmware update
Hi all! Happened a while ago. Last I recall, I updated to the latest firmware and can no longer access the admin page via the app or routerlogin.net. I get a connection timeout from the webpage ...
Sep 03, 2026Guru - Experienced User
eggt4rt wrote:My router still works as in I can connect to the internet from ethernet cable and WiFi. Just can't access the admin page anymore to configure anything.
Did the LAN subnet change? Have you tried browsing directly to the router ip?
eggt4rt
Sep 03, 2026Aspirant
Hi Stephen! If the LAN subnet did change, I did not do it. I have tried 192.168.1.1 (if that is the correct IP). After the update, the app used to see it and tries to connect. With the latest app ver (2.54.1), it doesn't even see it at all.
- StephenBSep 03, 2026Guru - Experienced User
Check the IP address on the client device you are using. If that isn't 192.168.1.x, then the subnet has changed.
