RedSevens
May 25, 2021Guide
R7900P - Upgraded Internet Package - Wifi Barely Improved or Same
Hi, I have scoured the net trying to find a solution, but there seems to be no common solution. I upgraded my speed from 100/5 Mbps to now 400/10 Mbps. Did this yesterday. For a while my spee...
- May 26, 2021
so your wired device is getting full speed.
you didn't list much specs for the testing devices.
What actual phone is it?
What wireless chip is in the laptops you're testing in? (a 1x1 wireless card will perform at half the speed a 2x2 will)
If you're going to try a different firmware, the one I'd recommend for that router would be 1.4.1.42
Its the version prior to netgear armor.
RedSevens
May 25, 2021Guide
Hi Plemans,
Here's the info and thanks.
What actual modem do you have?
(Modem is Arris SB6183
https://www.surfboard.com/products/cable-modems/sb6183/ )
(Router is Netgear Nighthawk R7900P
https://www.netgear.com/support/product/R7900P.aspx )
What firmware version are you on?
(Netgear Firmware Version
V1.4.1.68_1.3.28 )
Try this.
Factory reset the router 1 more time. During the reinstall, leave everything at the defaults.
(Done. Tried two ways this time. 1 time with usual hard reset and also 1 time with the 30-30-30 method of hard reset.... But ended up with about the same results below... Did not adjust any settings from the defaults)
Once installed, test the hardwired speeds and then the 5ghz speeds.
(Hard wired speed is roughly 460 Mbps.
5Ghz_1 hit about 136 Mbps.
5Ghz_2 hit around 137 Mbps. So the 5ghz are roughly the same).
V1.4.1.68_1.3.28 )
Try this.
May 26, 2021Guru - Experienced User
