barrystark
Jun 03, 2022Follower
R7900P-100NAS firmware update
I bought this unit a few years ago and started to have problems with it dropping the network connection. When I looked at the firmware upgrades available the notes said that the later firmware does n...
Jun 05, 2022Guru - Experienced User
How many wired and wireless devices do you have connected?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
How do you have Advanced Wireless settings configured?
