HolmGear's avatar
HolmGear
Initiate
Jul 29, 2019
R7900P 2.4Ghz broke completely after recent Firmware Upgrade. I tried all modes and it does not work
NetGear offered a Firmware upgrade which I installed lastnight. It was successful, but 2.4 Ghz band broke completely after the upgrade. I have some devices that can only do 2.4 Ghz and they are all d...
  • plemans's avatar
    Jul 29, 2019
    Its always good to reset a device after a firmware update. As well as making sure to do it over a hardwired connection. Did you try reloading the firmware over a hardwired connection and resetting it post update?
    Which firmware did you load?
    If this doesn't fix it, you can try downgrading the firmware. You accomplish this in the same route as doing a manual update but using the old firmware. You can find it at the device support page, bottom of the downloads section under +view previous versions.
    https://www.netgear.com/support/product/R7900P.aspx
