Jiggsman
Dec 17, 2020Follower
R7900P 5GHz-2 not available and then sometimes resets to an unsecure, default named, network
Hello friends, I searched and saw some similar issues on these forums, and others, but did not see a fix. Firmware version: V1.4.1.64_1.3.25 I recently updated to this firmware and, because I...
Dec 17, 2020Guru - Experienced User
Try reinstalling the firmware over a hardwired connection. once reinstalled, factory reset and reinstall the router. don't use a backup configuration during install. See if that helps.
