DryHeat
Jul 30, 2021Aspirant
R7900P Broadcasting Unprotected Availability on 2 5G Radios
I have noticed that my R7900P is broadcasting free access on the two non-guest 5G radios. I'm not configuring them to do so, but anyone can connect. I've testing with various devices. No passwo...
- Jul 31, 2021
I verified those were from my router by doing proximity checks measuring the distance from phone to the router as well as powering cycling my router.
However, I have resolved the issue - at least temporarily.
I disabled and the re-enabled smart connect.
The reason I say it's temporary is that there is no guarantee this won't happen again.
michaelkenward
Jul 31, 2021Guru - Experienced User
I'm not configuring them to do so, but anyone can connect. I've testing with various devices. No password is required. These should not be even broadcasting.
How do you know they are from your router?
It may be some time before the images land. To ensure that you aren't posting anything naughty, a Netgear moderator has to approve the pictures.
You can attach images to messages without any delay.
Have you checked your setup for Guest networks?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual
Manage the Basic WiFi Settings and WiFi Security of the Guest Network
DryHeat
Jul 31, 2021Aspirant
