SiouxOrch
Jul 01, 2021Aspirant
R7900P can login via URL but not via app
Tried the app on an iPad and 2 iPhones. Neither work. Enter username/password but it just comes back to the same screen with the same username/password I entered. Eventually says timed out. I can...
SiouxOrch
Also, I tried connecting with anywhere access and it says it's offline. Also tried new setup, but always the same with the nighthawk app.
Kitsap
Jul 02, 2021Master
You should take this as a really big hint to ditch the application, it is of dubious value. Would not hurt to competely uninstall it.
Anything you need to do to configure the router is best done from a PC connected to the router with an ethernet cable.
