DryHeat
May 16, 2022Aspirant
R7900P Date/Time Incorrect
Router type: R7900P Firmware Version V1.4.3.88_1.3.50 My current date and time are incorrect. Start Date/Time: Monday, 01 Dec 1969 00:00 Current Date/Time: Wednesday, 31 Dec 1969 18:26 E...
- May 16, 2022
have you tried changing the ntp server?
Or checking the settings?
Not 100% sure if that device has it as i don't have one but if it does, it'll be under the advanced tab---->administration---->ntp settings
May 16, 2022Guru - Experienced User
- DryHeatMay 16, 2022Aspirant
Thanks for the prompt suggestion. Apparently I'm no longer able to connect to pool.ntp.org.
