i58_Jess
Aug 02, 2022Aspirant
R7900P Ethernet
I use Windows 10 computer connected to my R7900P with ethernet and wirelessly. While the wireless is fine my ethernet does not connect to the internet. It says Unidentified network.
Aug 02, 2022Guru - Experienced User
What CAT# lan cable are you using between the router and this PC? CAT6 is recommended.
Ensure the ethernet drivers are up to date on the pc as well.
Does a different PC experience same issue?
Have you powered OFF the ISP modem, router and this PC for 1 minute then back on in the following sequence? Modem, Router then PC?
Is the LED on the router ON when the ethernet pc is connected to the ethernet port on the router?
- i58_JessAug 04, 2022Aspirant
The PC that I was working on regarding this issue has died so thank you for your reply but for now this is a mute issue.
- i58_JessAug 09, 2022Aspirant
I have the same issue as described here. I have the same issue with my Laptop and Desktop.
R7900 Connected through ethernet to am R6300 then from the R6300 to my PC. It used to work up until a couple of weeks ago.
I have not initiated any changes
- FURRYe38Aug 09, 2022Guru - Experienced User
So remove the R6300 from between the R7900 and your PC?
Your replies are not understandable. You say the problem went away and now your have another problem?
Sorry, I had worked on this issue, and in the middle of that, I had to reinstall Win10 so that computer became inoperable.
I have the R6300 connected to the R7000 using Ethernet to extend the wireless range. The R7900 is connected to a Cable Modem out to the Internet.
- michaelkenwardAug 10, 2022Guru - Experienced User
You are using two routers on the same network?
As FURRYe38 explained for that to work, the second router should be in AP mode.
I connect the PC directly to the R7900 and it sees a wired connection but cannot reach the Internet (Cable Modem).I cannot log into the R6300 so, for now, I cannot confirm its settings. I will keep trying.
When you have the router in AP mode, you need to track down the local IP address of the AP router, either through its wifi, the "attached devices" listing in your browser graphical user interface (GUI) or with something like the desktop genie and its network map.
As FURRYe38 also says, it is kind of difficult to follow your explanations of what is going on.
- i58_JessAug 11, 2022Aspirant
Sorry that I am not being clear but this is not my area of expertise so I am trying as best I can.
I did shut down the Cable Modem and both Routers (R7900 & R6300).
I connect a Laptop directly to the R6300 and can see it using the Genie but that does not show whether I am in Bridge (AP) mode.
I tried to connect to the R6300 with a Browser but it always connects to the R7900 so I do not know how I can ensure that I am in AP mode.
