BillS22
Oct 16, 2021Star
R7900P Firmware Issue Version 1.4.2.84 / Browser Issues
After upgrading my R7900P to Firmware Version 1.4.2.84 I started getting Browser Issues. Both Chrome and Edge would fail loading web pages. I down graded the firmware to the last previous versio...
- Oct 17, 2021
Thanks for the reply.
I didn't reset because I have been using this router for a long time with no firmware issues until now.
Also, I have been using the Armor / Bitware Protection for nearly to years, and again have not had an issue until now.
So, I am convenence it's the Firmware: 1.4.2.84. Perhaps it's a get-ready-for-Windows 11 issue.
Many software suppliers are re-writing their apps in preporation for Win 11.
I don't know, and I am running Win 10, not 11. But I've never had a Firmware issue until this version.
I'm happy sticking with 1.4.1.68 until ver 84 is fixed.
Thanks again for the response,
Bill
ilteq
Oct 16, 2021Aspirant
I upgraded my R8000P to version 1.4.2.84 today and have been having the same problems. Web pages randomly fail to load on both wired and wireless devices. I factory reset the router and the problem was still there.
I then downgraded to 1.4.1.68 and the problems are gone.
Oct 16, 2021Guru - Experienced User
Thannks for confirming.
Enjoy.
