BeaMeUp
Mar 14, 2020Guide
R7900P Firmware update failed
I received an email today with a security update notice for my Nighthawk. So I logged into the router and did the check for update, if found one, so I applied it. I failed part way through, somethi...
- Mar 15, 2020
Good write up on debricking a router using a MAC. Have used it. Follow instructions and should work. This will work with most Netgear routers.
BeaMeUp
Mar 15, 2020Guide
Just an update. I started using Terminal in OSX. It connects, and it seems to stay connected as pings don't fail. I "put" the firware file and it says "sent" with no errors. But still doesn't load the firmware. BTW it's the .chk file I'm sending.
Anytthing I'm doing wrong there? Only command i gave TFTP is verbose.
In the TFTP GUI I was using binary as the file type. Didn't see that option with terminal.
I just read about the extra heavy reset. I want to exhaust other options 1st.
Maybe I can try an older firmware?
labatt
Mar 15, 2020Mentor
- BeaMeUpMar 15, 2020Guide
Absofrikkinlutely :) :)
binary command was all I needed.
It's all back up and my configuration is still intact. Wow!!
Guess that factory reset didn't do squat while it was bricked.
Thank You!
Thank You!- BeaMeUpMar 15, 2020Guide
Let me add a note in case someone else comes along.
Don't bother with the TFTP software for OSX. It didn't work. Use the Terminal.
If you place the firmware file in the root directory "username/firmware_v1.2.3.4.chk" (example),
then you won't need to do anything but enter the "put" command. It will find it.
And in hindsight, I probably had v1.4.1.24, or that's the last one I remember, as there was a version between these, v1.4.1.30- labattMar 15, 2020Mentor
Glad you got things working again. Hard to find good info on recovery when using a MAC. I have both, and challange myself to try with the MAC as I know somethings would be so much simpler with Windows, but not everyone has a Windows PC available. Want the knowledge to help others.
