jfausmith
Dec 09, 2020Aspirant
R7900P FIRMWARE UPDATE
I received an email from Netgear letting me know that there was a firmware upgrade availble and that I should download and install it on my router. I used the app on my iphone to check to see if the...
- Dec 10, 2020
Those emails go out from time to time. There seems to be no logic in the timing.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have a library of firmware and drivers for your device.You can look for more recent firmware. You can even download a copy and install it yourself, which is a more reliable method than using an app and wifi.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
jfausmith
Dec 10, 2020Aspirant
I want to thank everyone that offered me assistance with this issue. I ended up going to the netgear link I was given and downloaded the firmware upgrade and installed it onto my router. Of course that ended up reseting my passwords and changing my logins. Not a problem so I just reset all of my login names & passwords.
Thanks again for the help.
michaelkenward
Dec 11, 2020Guru - Experienced User
It shouldn't be "of course". Firmware updates rarely reset the device. That happens only with major updates. You can also reduce the hassle by saving your settings before you do the upgrade and restoring then after if the thing does reset itself.
