jfausmith
Dec 09, 2020Aspirant
R7900P FIRMWARE UPDATE
I received an email from Netgear letting me know that there was a firmware upgrade availble and that I should download and install it on my router. I used the app on my iphone to check to see if the...
- Dec 10, 2020
Those emails go out from time to time. There seems to be no logic in the timing.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have a library of firmware and drivers for your device.You can look for more recent firmware. You can even download a copy and install it yourself, which is a more reliable method than using an app and wifi.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Vicors15
Dec 30, 2020Aspirant
How can I update the firmware
michaelkenward
Dec 30, 2020Guru - Experienced User
Support | NETGEAR
Check the section in the manual on updating the firmware.
