DASty
Feb 05, 2023Aspirant
R7900P Firmware Version V1.4.4.94_1.3.56 Reserved Address issues
I can't seem to get the Address Reservation to work as instructed. When I am on the LAN Setup page, no devices are listed under the Address Reservation bar. The Help says: To reserve an IP address...
michaelkenward
Feb 08, 2023Guru - Experienced User
If you can't get it to work on the router, depending on what you want to achieve, an alternative is to go to the device that you want to fix and tell that to use your preferred IP address. This can work with things like printers and NAS boxes.
