riccibru's avatar
riccibru
Initiate
Oct 17, 2021
R7900p fR7900P-V1.4.2.84_1.3.42 problems
Updated to new firware V1.4.2.84_1.3.42 . -Having problem when accessing some internet sites, i had to continuisly reload. It seems these site may take longer to respond. Enabled "Airtime Fairness " ...
  • plemans's avatar
    Oct 17, 2021
    3 things to try.
    1. try enabling IPv6. That's helped in some instances.
    2. try factory resetting and reinstalling. sometimes after a firmware update, old settings can cause issues.
    3. if that doesn't help, try downgrading the firmware a version. some of the newer firmwares caused dns issues.
