riccibru
Oct 17, 2021Initiate
R7900p fR7900P-V1.4.2.84_1.3.42 problems
Updated to new firware V1.4.2.84_1.3.42 . -Having problem when accessing some internet sites, i had to continuisly reload. It seems these site may take longer to respond. Enabled "Airtime Fairness " ...
- Oct 17, 2021
3 things to try.
1. try enabling IPv6. That's helped in some instances.
2. try factory resetting and reinstalling. sometimes after a firmware update, old settings can cause issues.
3. if that doesn't help, try downgrading the firmware a version. some of the newer firmwares caused dns issues.
Oct 17, 2021Guru - Experienced User
3 things to try.
riccibru
Oct 22, 2021Initiate
Set IPv^ to "Aotu Config" so far firmware V1.4.2.84_1.3.42 working ok
