budhabelly's avatar
budhabelly
R7900p guest WiFi password
My R7900P refuses to accept any password that I try. I keep getting the message “unable to update router settings”
  • Kitsap's avatar
    Kitsap
    Mar 15, 2023
    budhabelly wrote:
    I really appreciate you taking the time to respond. I gave up on using the mobile app and went back to the tried true method of wired setup. It took all the settings on the first try.
    Very good.  Definitely a lesson learned.  Please mark this thread as resolved so others may benefit.
