jody923
Feb 17, 2021Follower
R7900P stops working
Began having streaming issues last night. This morning the internet and wifi would drop out. Works for a while after rebooting then craps out. Have tried rebooting, power cycling, hard power cycling,...
mmd2006
Feb 25, 2021Tutor
I can't tell from your description if the router is dropping the wifi only or is the whole thing including hardwire dieing. My router was dropping the wifi every few minutes (or less!!!). While it came back quickly, the lack of continuity made connecting and reconnecting smart devices difficult. I tried lots of stuff such as ensuring I have the latest update, moving to uncluttered channels, changing Fragmentation Length and CTS/RTS Threshold, trying to prevent IP address conflicts by reserving addresses, etc. What seems to have fixed it is turning off Smart Connect. Apparently, its not too smart.and even disrupts the Guest wifi.
A serious firmware update is needed to fix it.
- wcalifasFeb 25, 2021Prodigy
how long have you had the router for?
