rogersja
Jul 18, 2022Aspirant
R7900P using MAC address security will not allow iPhone to connect to internet
Hello, This is my first post. I'm having a strange issue with my Nighthawk. I use MAC address security on my router, and for years I've had no issues. As I get a new product or device, I get its ...
rogersja
Jul 19, 2022Aspirant
Hi Furrye38,
My router has firmware version: V1.4.3.88_1.3.50
The modem is from Spectrum, but I cannot make out the model #.
As to your suggestion to remove the MAC address security, I don't want to do that. The whole point of setting it up this way was to use the MAC address filtering. It that no longer works, I don't want the router.
Please let me know if you have other questions.
Thank you,
rogersja
Jul 19, 2022Guru - Experienced User
The test was to see if the phone connected correctly if you temporarily disabled the security on the router...
- rogersjaJul 27, 2022Aspirant
Hi Furrye38,
Yes, the phone connects when the MAC address access control is turned off.
