terraset's avatar
terraset
R7900P X6S keeps dropping 5.0GHz connection
Brand new router R7900P X6S running the stock firmware 1.1.3.2_1.1.74 keeps dropping 5.0GHz connections.  The RED line shows 2.4 GHz, the GREEN and YELLOW are 5.0GHZ. The spike in the signal strengt...
  • JamesGL's avatar
    JamesGL
    Feb 08, 2018
    Hi terraset,
    Please try to use a different WiFi Analyzer just to make sure of the issue you have raised.
