LokeYourC3PH
Sep 17, 2022Tutor
R7900P/R8000P CFE & firmware.bin & JTAG
Hello there dear NETGEAR community. I had bought from a friend a dud/bricked R7900P (PCB ID: U12H359T00, same as the R8000P) that he had brought with him from the US. I had checked with serial consol...
michaelkenward
Sep 18, 2022Guru - Experienced User
LokeYourC3PH wrote:
Again, this is the OFFICIAL NETGEAR forum, for NETGEAR hardware.
Not really.
This is essentially a user-to-user forum, with some input from a small band of Netgear support people.
You may not like the answers that you get, but I can assure you that being rude when someone offers a suggestion is not going to convince anyone else to offer different answers.
The Netgear team may not have the details you want nor are they in a position to dig deeper.
LokeYourC3PH
Sep 18, 2022Tutor
Having worked in plenty of support myself, a lesson that many should learn is that: If you have no proper answer to the actual topic/question at hand, provide nothing and just admit you don't know. It'll make everyone's time better and not waste anyone's time. I wasn't being rude, I was just merely stating facts that the reply truly wasn't contributing anything to the actual question I asked.
Anyways, on a whole different note, "community" or whatever, it is NETGEAR official. I've had plenty of help from TP-Link and ASUS back in the days, and what that sounds to me like right now is that NETGEAR doesn't truly want to support their customers with anything they really seek other than "buy new product". Which, quite frankly, if that is the type of reply I'll get from support (I opened a case) or from actual NETGEAR staff here on the community forum, will be my last NETGEAR product. I've been buying plenty NETGEAR over the years and been promoting it wherever I could, because I as a customer expect some help when I need it as well. As such, I am just hoping someone here can give me what I am seeking, as any other reply wouldn't help. I know what my issue is, and I know what the solution is, it is just that I myself do not have access to the files that NETGEAR staff has, or that some community members may have a backup of.
- FURRYe38Sep 18, 2022Guru - Experienced User
NG doesn't provide anything beyond the FW files that's posted on there download site. Anything beyond that needs official NG support or RMA that the unit would need to be returned to NG. I presume that the RMA is no longer an option as it's probably way out of warranty and is a hand me down. NG doesn't offer a repair service either. I wish they would but it's there show.
I know that the DD-WRT forums has had users post JTAG informations on some MFrs routers before. You might check there as they support some NG routers.
Only other suggestion would be to try the TFTP method and see if the router will take a FW load here.
Otherwise, if you can't get the unit running using normal or advanced means, then the unit should be deposed of and find something else.
- LokeYourC3PHSep 18, 2022Tutor
Have you ever had Serial Access and such before, or any technical knowledge at that level? Because if so, as you can tell from my logs, the bootrom works, but anything beyond that doesn't load, so if CFE doesn't load, then obviously TFTP wouldn't load either, that's a given. And again, their software/bootloader/firmware is all GPL, so they are able to provide it all without issues, I just need someone from NETGEAR staff that has the ability to do so or some community member that has a CFE/bootrom/firmware backup or can take one for me from their current hardware.
And yea of course RMA is out of question. Although, NETGEAR has a service centre here in Korea, so I might go to them if possible later down the line. Also, like I said, this is heavily discouraging for me as a future customer and for me to keep recommending NETGEAR hardware to many businesses as I have done so far, if basically ASUS and TP-Link do it far better. If this is "their show", then they gotta step it up or not be a business period, just my two cents on it, because if third-party sites do your job better in terms of providing help, then you really as a company should go back on yourselves and take a deep look at how you're handling things, no joke.
Last but not least, I've tried finding JTAG pinouts for any related NETGEAR router in the near serial/model vicinity (any Nighthawk model), but could not find any at all, as I am sure they are quite different for many of them, so taking just any old NETGEAR product might result in the thing going entirely poof. Also, what is it with this "modern" idea of, instead of fixing something, just "dispose" of it and "buy new product", hmm? Why can I not just fix my stuff like we were all able to back in the days. And hell I'm only 25 and am saying "back in the days", so that oughta mean something. It's all gone for the worse, I don't wanna always "buy new product" when my current one is perfectly fixable as is if someone provides me with what I am seeking, it's not like half of the board has burnt away or something, it does come as far as the first step of the bootrom, so it clearly functions on a hardware level, so why dispose of something that is perfectly in working order (more or less), and add more trash to our planet, as if we don't already have enough...?
Well thats a good perspective of course and I do agree with you.
I presume if we had access to the tools and devices that NG probably has that we could recover this router.
I remember analog dial up so age doesn't matter here. I've been working at this level and deeper for past 20 years.These are home class routers and are intended as such. Not meant for the business domain.
It's how NG handles there business and ya, it's how it is. You can make contact with NG support and ask to see what can be done as this is well beyond forum help here.
Good luck.
