rdhaduva1
Aug 26, 2021Aspirant
R7960P - blocking outgoing traffic to certain Ports. Does it Conflict with Windows Firewall Rules ?
Hello Experts, I desparately need help. Not sure if the problem i am facing is realted to my Router or not , but still wanted to share and seek assistance. Have been using my Nighthawk AC3600 Tri-ba...
Aug 26, 2021Guru - Experienced User
Did you disable uPnP if you set up any port fowards or triggers?
rdhaduva1
Hi Furrye38
Thanks for prompt response.
My NG router is connect to Verizon Modem - Actiontec MI424WR Rev 1
- FURRYe38Aug 26, 2021Guru - Experienced User
Your modem already has a router and wifi built in. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
