harrylevins
Jan 14, 2020Aspirant
R7960P - logging into router - does not ask for user name and password
When I log into the router using http://www.routerlogin.net, no login window opens. I am not asked for a user name (e.g., admin) or password. It goes straight to the main, six-screen page that shows ...
- Jan 15, 2020
Thank you so much for your reply. Your first thought was the correct one - a different browser brings up the login window. When I set up the router, a Cox technician was waiting for me to finish. Hurried, i must tolD the browser save the password, which is not my normal practice.
Thanks again for taking the time to reply at length and solving my issue!
antinode
Jan 14, 2020Guru
> R7960P [...]
> Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Which model is it? Firmware version?
> When I log into the router using http://www.routerlogin.net, [...]
Does a different web browser act differently? (Is your web browser
handling the log-in stuff automatically?)
If you can't blame the browser, then you might try a settings reset
(and manual reconfiguration).
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for
"reset".
When that fails, I might (in desperation) try a different firmware
version.
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions.
- harrylevinsJan 15, 2020Aspirant
