c_of_c
Jun 05, 2023Star
R7960P - "Respond to Ping on Internet" option selected and grayed out
Netgear Nighthawk X6S, model R7960P. Purchased at Costco. Running Firmware version V1.4.2.84_1.3.42. On the "WAN Setup" Page, the "Respond to Ping on internet" option is checked, but grayed out - so ...
- Jun 22, 2023
Update: I upgraded to the latest firmware (V1.4.4.94_1.3.56), and that has resolved the issue. I can now uncheck that option. Thanks!
c_of_c
Jun 05, 2023Star
"What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?"
Arris Surfboard SB8200
After the firmware update router was reset and reconfigured. Not using the IP addresses you mentioned as not permitted in this environment, and I do not see how the IP range could make a difference. Router functions fine, just that one option cannot be turned off.
Jun 05, 2023Guru - Experienced User
So after the reset and setup from scratch, you can't turn that option off or disable it?
What browser are you using? Try MS Edge or Firefox?
Try a reset on the router with the router disconnected from the ISP modem...
- c_of_cJun 05, 2023Star
I have done that a couple of times, still no change. Tried multiple browsers, no change. Probably the best thing to do is to upgrade the firmware, which I will do in a few minutes. I was trying to figure out if it was grayed out due to some other setting, but I do not see anything that could be doing that.
I have attached a screen shot to show what it looks like.
- c_of_cJun 22, 2023Star
