CKopp
Oct 02, 2022Apprentice
R7960P - Router failing or?
Unusual Problem just cropped up. The router fails to work periodically. When that happens lights all seem to work (lit or flashing periodically) except you can't connect to the router. Interesting...
Oct 02, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Try setting a default DHCP IP address range of .100 to .200 instead of the larger pool size.
Does the router feel extra warm or hot when this happens? I keep a laptop cooler fan under my router for 24/7 cooling.
- CKoppOct 02, 2022Apprentice
The modem is hard to get to, it is a ISP Charter supplied modem (Spectrum make Docsis 3.1 rating).
Cable is either Cat 6 or Cat6/E. Top of the line patch from mono price.
Yes I performed such a cycle before the last 12 hours between failure. But the majority of time I just have been shutting of the router, waiting 30 sec and turning it back on.
No I have not done a factory reset from scratch. I will consider trying such a move, but keep in mind the last firm ware upgrade was several months ago, and this problem only showed up a couple weeks ago.
I am trying one change at a time, want to see how this IPV6 change (from 6to4 to DHCP) impacts things. If still happening, I will first try turning IPV6 off. Then I'll try a reset.
My DHCP pool is already restricted .002 to .037.
Does turning on IPV6 stress the router more (especially the 6to4 tunnel setting)?
No the router is warm but not at all hot. I also blew it out with compressed air to make sure no dust impeding cooling transfer.
So far, after the change to DHCP on the IPV6, it has not crashed yet and I have hit the 12 hour mark (fingers crossed)
- FURRYe38Oct 03, 2022Guru - Experienced User
Auto should be used for IPv6. I think 6to4 is being depreciated.
Let us know how it turns out.
- CKoppOct 03, 2022Apprentice
Yes, I am not sure how 6to4 tunneling was originally set, I thought when I turned on IPV6, I specified Auto Detect. But 6to4 is next option in list so maybe I overshot.
So far its been stable for 24 hrs but I am monitoring. Do you know how routing works with IPV6 and IPV4 turned on simultaneously? IS there an attempt to route via IPV6 first with the IPV4 attempt a fallback?
