CKopp
Oct 02, 2022Apprentice
R7960P - Router failing or?
Unusual Problem just cropped up. The router fails to work periodically. When that happens lights all seem to work (lit or flashing periodically) except you can't connect to the router. Interesting...
Oct 06, 2022Guru - Experienced User
We keep asking and pushing on this. Ya it's across the board for R series routers for DNS issues. Possible IPv6 maybe broke as well since the IPv6 package could be out of date. No idea if or when NG will fix em. Trust me, we understand the frustrations. 🙄
CKopp
Oct 06, 2022Apprentice
I just updated to the firmware that just came out (.94). First time in several updates where it went smooth, updated from browser page, router downloaded and updated, rebooted and came right back up.
First the good news. I tested for about 50 rapid fire web loads off my favorites list . Every single one loaded lickety split. NO DNS probe errors! This may be the fix we have been waiting for!!!! (under previous FW, the farthest I could get was 25, and loading was often delayed)
Regarding my recent issues with crashes: I have now disabled IPv6 as it doesn't seem that it is necessary for proper DNS resolution and will monitor.
- FURRYe38Oct 06, 2022Guru - Experienced User
Kewl. Seems that just arrived. I'll get it posted.
Keep us posted on how it goes. If IPv6 is disabled and using normal DNS, hoping NG finally fixed the DNS issue. - CKoppOct 06, 2022Apprentice
Well, it has now been a few hours.
AN observation: 1. DNS does not appear to be fully fixed. It is noticeably better in that the DNS probe message does not pop up as often, and when it does, resolves itself after a couple seconds, vs. before when it would require one or more reloads.
I will try re-enabling IPv6 to see if that fixes the problem without crashing under new FW. Stay tuned.
Ok. I just put mine online and and IPv6 is disabled.
I haven't seen anything so far but will give it a few days to see what I find.
You might fully clear out the PC DNS and ALL Browser caches before re-enableing IPv6. Be sure it's all clear then start testing over.
- CKoppOct 09, 2022Apprentice
Ok, enabling IPv6 did not help much. I get about 30hrs between crashes. So I ma trying the last part. Running with IPv6 disabled again.
- FURRYe38Oct 09, 2022Guru - Experienced User
Are you streaming or is the router under heavy load when the crash happens?
Wondering if there is something else going on with your Router. Doesn't seem like this is a FW issue. Thought I did a factory reset and setup from scratch yesterday since I fiddled with IPv6 and it was enabled by accident, Mines been online since the day the new FW appeared and has been online solid. No DNS issues seen so far. 32 Devices connected.
Possible there is something causing the router to crash or the router maybe faulty.
I keep a fan under my router for additional cooling.
- CogXOct 10, 2022Aspirant
I had never messed around with IPv6 settings on my R8500, but given that the current firmware revision (08/05/2022) didn't fix the DNS errors, I took the advice of others posting on this site and enabled IPv6. It seemed to fix the DNS errors, but alas every so many hours my R8500 was crashing/spontaneously rebooting itself. After a week and three separate crashes, I once again disabled IPv6 settings. A crashing router (which then takes a minute or two to boot back up and work again) is worse than sporadic DNS errors... although still unacceptable.
Until I can figure out a proper router replacement (a DEC695 is just really expensive), I've copped out and hard-coded DNS server addresses on my main computers and main streaming device; haven't bothered messing with every device in my house, as this entire exercise is infuriating, but I'm at a "good enough" place right now I guess.
I'm not even angry at Netgear anymore, because clearly their code base has a fundamental flaw in it to be affecting so many products and after this many months without a fix it is obviously something their programmers are simply stumped about. I'm more just sad, because as I look at reviews of their direct competitor's products and I can't find a happy customer with any of it. Clearly this an entire consumer product category riddled with buggy code and ultra-cheap manufacturing.
- FURRYe38Oct 10, 2022Guru - Experienced User
If your seen crashes across two different model routers, I feel this isn't a FW issue mostly however, maybe a configuration issue or something connected to the router, devices or ISP modem that maybe causing these crashes. I also have a 8500 router as well hand have not seen this with IPv6 enabled to help with the DNS issue.
I've had my R7960P online for 4 days now with IPv6 enabled by accident so I saw no DNS issues. I factory reset Saturday and no IPv6 disabled, two computers saw DNS Probe/Proxy messages though quickly disappeared on some sites we had visited. I've passed this on toe NG for review. Router has not crashed or auto rebooted.
- CKoppOct 10, 2022Apprentice
I have been running for a couple days now with no crashes. I have IPv6 disabled again. The DNS resolution issue still exists, although it is a bit better than before in that the DNS probe failure message typically resolves itself with 2-3 seconds after popping up. I have gone back to specifying DNS manually on my several windows workstations.
The crashes seem to happen under all different loads. At night when no one is awake. During streaming of Netflix on a single TV. In the middle of one person doing a web browsing session. In the middle only one person active on a zoom session. The router is warm but never hot.
Not sure why at least two of us are experiencing crashes with Ipv6 enabled while you are not. But it never crashed before I enabled IPv6 (even with several users and simultaneous 4k streaming on two streams), and no matter what I have tried (6to4, Auto detect, or Auto Config) IPv6 seems to cause the router to lock up. It will not accept attempts to connect to it, and the machines on DHCP connected to it lose their IP assignments.
My network is pretty standard. About 14-20 devices connected at one time (router typically shows 14 connected). 4 -6 laptops or workstations (never more than 3 actively being used). 3 Streaming TVs, two additional streaming devices, one Iphone, one android, one Ipad, two printers (only one has internet connection), two NAS devices, two IOT devices - (arlo hubs).
I believe the device is billed as handling 40 simultaneous connections. Does the number drop substantially if IPv6 is used? I
Ya. I caught these few DNS probes again yesterday. I've passed this on to NG for review. They are looking into it. Again.
Only thing I don't have is 4K TVs. Other then those, Just added two IoT bulbs, have 2 NEST Controllers, 3 game consoles, two Apple TVs, DISH Hopper system, 3 printers with static IPs. 2 NAS with static IPs outside the routers default IP address pool, 6 PCs and a Macbook. Iphones and apple and android pad. Have a ASUS GT-AX11000 wirelessly bridged to the router and a RAXE500 wirelessly bridge to the router. 2 NG multigig lan switches, 24pt HP 1Gb switch for main home network and NG GS105 switches daisy chained at the end points.
I believe the device is billed as handling 40 simultaneous connections. Does the number drop substantially if IPv6 is used? I Don't think so.
Would you configure your router as seen here like I have mine?
Keep SSID and password that you set of course.
What is the model # of the ISP modem?
Only thing we might try on yours is turn off ALL non critical devices and run with a limited count of devices if you can for say 12-24 hours and see if this changes anything. Still wondering if something on your network is causing this router hang since you said you saw this on your R8500 as well.
2+ days of uptime with IPv6 disabled with 31 devices connected.
I forgot to mention the switches 1 NG 24 gig switch, 2 8 port 1 gig. 1 10/100. That was the other guy with the R8500, my backup router is the R6700 (ready to go in box if I completely go down). The modem is Spectrums, it IS a Technicolor Docsis 3.1 model E31T2V1. I'll take a look at the difference between your config and mine.
We have similar configs except:
I am using the 192.168.1.xx IP range
I do not have smart connect turned on
I was using default DNS, but for past year have been using Cloudflare's DNS (at least before the most recent FW upgrade, I tried a bunch of DNS services including Google and the ISP - did not make a difference on the DNS issues)
WMM is enabled on mine but I can't tell if it is on yours.
I do run Armor, which once I bought subscription a couple years ago, has been on ever since (and I have no way to disable from the web console)
SO far I have been up for 32 Hours, longest time in a while.
- FURRYe38Oct 11, 2022Guru - Experienced User
I am using the 192.168.1.xx IP range < Try setting the range to 1.100 to 1.200.
I do not have smart connect turned on <Something to try with enabled.
I was using default DNS, but for past year have been using Cloudflare's DNS (at least before the most recent FW upgrade, I tried a bunch of DNS services including Google and the ISP - did not make a difference on the DNS issues) < I use default ISP DNS. Sometimes Quad 9
WMM is enabled on mine but I can't tell if it is on yours. <Always enabled on mine.
SO far I have been up for 32 Hours, longest time in a while. < So what did you change? Disabled IPv6? Wondering if IPv6 and Armor enabled could be something to look at? I don't have Armor enabled on mine.
3+days of up time. No Hangs:
I'll probably be moving the 7960 off line and putting something else online while we wait for NG to continue to fix the FW. 🙄
- CKoppOct 12, 2022Apprentice
Well, its been over 3days uptime and no crashes. The only thing different is that I have disabled IPv6. As everything worked fine before (except DNS issues) for years, and the trouble started after I enabled IPv6 (both on the 3.88 and the 4.94 versions) I can only come to the conclusion there is an issue with the IPv6 FW implementation and either my router hardware, or something else on my network (although I am hard pressed to see how another device could crash the router only when IPv6 is enabled). Guess I'll wait for the next FW update and hope that fully resolves using router DNS. Thanks for trying to help me.
- FURRYe38Oct 12, 2022Guru - Experienced User
Ok, I saw no crashes on my with IPv6 for a short day or two I had it enabled. Not sure why yours is crashing.
From what I see, users are posting that v.68 seems to be the best version for DNS and IPv6. You might revert to that and hold.
I've passed all the current and new bug information to NG for review. They've ack'd receipt. So just have to wait for now and use what works. 🙄
Yes, I agree. But as I am unwilling to give up three iterations of security fixes, I will go back to specifying DNS on individual PCs. Also, don't know if this matters, but I do run Armor on that router.
Thats something I don't run on mine. So something you might try. Since you have had Armor enabled. I'd factory reset it, setup from scratch, don't enable Armor. Enable IPv6 and see if crashes still happen.
- CKoppOct 16, 2022Apprentice
Its been over a week, no crashes as long as Ipv6 not enabled. I have spent a lot of time messing with this, and am more inclined to go to a different companies router than keep messing with this one. I have considered a reset, but as I have no way to enable or disable Armor, and I have to check and reset all my settings, that seems to be another waste of time. For now, I will wait for the next FW release, which hopefully resolves all DNS issues on IPv4, and I'll ignore IPv6. Thanks for your help! Not sure why NG has such a problem getting this DNS issue resolved. Its a real shame, I have used dozens of their switches, routers, etc. and recommended them to many friends, family and clients in the past. Not so comfortable doing that these days.
- FURRYe38Oct 16, 2022Guru - Experienced User
You can try loading up v.68 as well as others report that version seems to be last working version of FW for IPv6 and DNS.
Ya were trying to keep NG on the DNS issue. I'll presume there maybe a Armor and IPv6 issues on yours that seems to be crashing yours. As of mine, with and with out IPv6 didn't crash and Armor was not been enabled.
Yes, I suspect that would work, (as that version worked fine before) but then I am giving up 3 releases of security fixes. This way is a bit spit-ball and twine, but it works and I am patched up for security.
