Moba24
Sep 28, 2022Aspirant
R7960P Changed firmware due to security concerns. Now I'm even more worried. Can someone look logs
R7960P Changed firmware due to security concerns. Now I'm even more worried. Can someone look at the logs? I changed firmware. I thought I had the newest but the site said there was a newer firmware...
Sep 28, 2022Guru - Experienced User
Do you have any Apple devices, if so, disable the WiFi Private IP Address feature on these devices while at home. This feature when enabled will appear as a "DEV" or unknown device on the routers web page. This feature randomizes the MAC address on Apple devices. Thus causing the router to display a unknown or DEV host name.
