Moba24
Sep 28, 2022Aspirant
R7960P Changed firmware due to security concerns. Now I'm even more worried. Can someone look logs
R7960P Changed firmware due to security concerns. Now I'm even more worried. Can someone look at the logs? I changed firmware. I thought I had the newest but the site said there was a newer firmware...
Sep 28, 2022Guru - Experienced User
Do you have any Apple devices, if so, disable the WiFi Private IP Address feature on these devices while at home. This feature when enabled will appear as a "DEV" or unknown device on the routers web page. This feature randomizes the MAC address on Apple devices. Thus causing the router to display a unknown or DEV host name.
Wxstrn
Firmware Version
V1.4.3.88_1.3.50
BASIC
Getting weird site not secure
CM2000 Netgear is modem
V1.4.3.88_1.3.50
BASIC
- FURRYe38Sep 28, 2022Guru - Experienced User
What site is this and on what device are you seeing this on?
- WxstrnSep 28, 2022AspirantJust the normal 192. I changed to https but turned that off. All devices
- WxstrnSep 28, 2022AspirantWeird on wifi my iCloud wasn’t updating and was getting cannot connect to server and said last updated was 7/14/22 then went to mobile and was fine and refreshed wifi and it’s working. Im probably going to change routers.
- michaelkenwardSep 29, 2022Guru - Experienced User
Wxstrn wrote:
Getting weird site not secureWhat is he exact message?
If that is in your browser, try another one.
Browser makers keep changing their approach to security. Something that works one day can fall over after an update.
Another possibility is your operating system, Windows, for example, tries to defend us from the cruel world and sometimes gets overprotective.
Did a bit deeper to see what is going on.
